Starting hesitancy 1930 Chummy
#31
Thanks - that thread from 2019 helps.
Hi
Attached is a rather better pdf drawing with the 26VA parts identified.  Operating the choke also invokes a fast idle by means of a cam and interconnection link.  This should give the correct throttle opening for starting without touching the throttle pedal.
.pdf   Austin Seven 26VA Carb.pdf (Size: 277.72 KB / Downloads: 54)
