Introduction from a New Owner!
#31
There is a lot of play in the big ends. I tried to post a video, but I don’t think it is possible. About 1/32 of an inch. I presume this is not normal!
Hi
I’ve found the best way to post videos is to make a YouTube video then post the link.
Here is a link to the youtube video.
https://youtu.be/s2cO1E7hDfM
Are these shims normal? Seems a horrid solution if they are! All four conrods have them in varying numbers!
Looks like a rebuild by Signor El bodgero.
Some Rolls Royces had shims like that
Shims were a normal and accepted practice back in the day.
Hi
The side play on the big end bearings can be up to 1/16” according to Woodrow’s ‘The Austin Seven Manual’.  If you don’t have this book I would definitely recommend it. It is stocked by Cherished Suppliers and available from ‘Mercury Vintage Services’ susan.woodrow@gmail.com.
Shims and side play aren't necessarily and issue.
Clean up the big end and share a picture of the bearing face too.
C
Thank you all! I have ordered a copy of Woodrow!
1/16th play sounds a huge amount!
There are definitely problems ahead though…
Had shims like that on a 1927 side-valve Riley I once owned. Seems they were the norm way back then.
