Thank you for all the reply's, as i expected it was a mixed bag of varying opinion. Going forward i will probably use all metric on the bodywork where it is less likely to be removed at the roadside and leave all mechanical and running gear as intended.
Here in Texas I can get Metric or Imperial very readily, but the Imperial is, of course UNF / UNC, or "standard" as it's labelled here.
Fortunately I don't have any BS threaded cars, though my Lotuses ensure I use both the others. I guess from the answers that UN isn't readily available in UK nowadays? I must say that from an appearance viewpoint, UN fasteners are more attractive as BS substitutes than are Metric.
Car type: 1932 RN saloon
The unf screws have a dimple in the centre of the head which is a good way of distinguishing them from bsf/bsw.
For the smaller sizes at least,BSW and UNC are virtually the same.
Not BSF and UNF though
Metric I can understand but UNF/UNC?
I concede there is 1 UNF thread on my car, but it is so Loctited as to never again be undone.
I’ve been able to buy UNF/UNC for my Plymouth Road Runner here in the UK easier than BSW/BSF!
Don't disagree Roger but the whole UNF/UNC venture seems like a wrong turn with hindsight. Funny how each successive attempt at standardisation has merely resulted in another layer of confusion.
What really bugs me is to see modern bolt heads with raised letters. These should be machined off. Oh for the days of the Williams Brothers fasteners factory in Sheffield. You could ask at the counter for some obscure fitting that needed to be, say, fully machined and chemically blacked. On one occasion the sales chap said that I'd better come with him to check, as he didn't want to traipse around the building putting stuff back. Off we went down a long corridor, taking the second set of stairs on the right; up two floors, another corridor, a flight of stairs to the left and stopped half-way down a set of shelving packed with boxes. He reached up, selected a carton and said, "Are these right?" They were. I asked if the location of everything was logged in a book; He replied in the negative and tapping his head said, "It's mostly in here."
