01-02-2019, 12:04 PM
01-02-2019, 12:38 PM
01-02-2019, 12:42 PM
so how DOES that space heater work, and what is it comprised of?
01-02-2019, 01:08 PM
Lots of moisture ??
01-02-2019, 02:00 PM
(01-02-2019, 12:42 PM)JonE Wrote: so how DOES that space heater work, and what is it comprised of? It's the same as this one: https://www.ebay.co.uk/itm/12V-5KW-Air-D...3289270349 It works pretty well but I am only on day one of using it!
01-02-2019, 02:37 PM
Take care with the exhaust gases, perhaps OK for a car porch
But not for an enclosed space unless you pipe away the exhaust? I prefer the coal fire method of engine assembly :-) All the best Bill G
01-02-2019, 03:18 PM
As you will have guessed, this is a test run Bill - it only arrived last night. I have exhaust pipe and wall boring equipment to use, once I have decided where it be installed...
I do have a beautiful 1920s (?) coke fired kitchen stove that I intended to put into the garage, I have not done so because of the quantity of inflammable stuff I have, pity as it it would be very cosy with it and it looks wonderful!
01-02-2019, 03:35 PM
Ah, very interesting. I've always wondered how efficient they are in relation to electric heaters. Have you researched in order to choose this route?
01-02-2019, 03:44 PM
A friend reccomended it... will let you know my thoughts once it's installed and in use proper.
01-02-2019, 04:13 PM
5KW is pretty hefty. It sounds as if it’s a truck , or boat cabin heater,
Which are normally about £800 to £1000 for an Eberspacher type gadget. If I had been flush I think underfloor heating in an insulated garage would Be the best solution. Does anyone have such luxury? Regards Bill G
Users browsing this thread: 62 Guest(s)
