Hi Simon
1925/26 factory Austin 7’s were fitted with silencers which had an integral
Stubby tailpipe. See the page from a period Spares book.
The tail pipe exits to the side of the rear wheel, it doesn’t direct
Any oily fumes towards the tread of the NS rear tyre. I once had a
near accident with that issue on a VW van.
The fumes might be a cause for concern if stopped in the one place with
the engine running for too long.
In a nippy little car like the Cup I don’t plan to linger long in any
One place!
Hope you find a good routing for your own exhaust.
Bill G
Hi Mike, Funnily enough you must telepathic !!!
I stuck it on temporarily and meant to check how it was positioned
In period photos and was actually doing that, just before I opened
Your unhappy response!!!
From looking at the period photos on Ruairidh’s GE
Site I can see that it needs to go at a more jaunty angle
and line up with the Head lamps( Which I cant fit as the rad shell
Is still at the platers. So I promise to put it all right for you....
Almost 25000 views of this post since August 2018 means a
lot of people are watching this build and aren’t shy at constructive advice,
which mostly I take on board.
I must see if I can recall/repost the earlier posts showing
The body being built.
Bill G
Dear Timothy
You are a true friend!! Thank you so much
For combining my musings about how to spend 3 years
trying to build a car from the chassis up!!!
I really appreciate your kind efforts and hope to meet you
sometime in the future to give you a spin in the Cup
Kindest regards
Bill G
Car type: 1928 Mulliner Fabric Saloon
You are most welcome Bill, It's been a pleasure watching your progress over the years.
I'll look forward to that!
All the best.
I Hi Mike
I’d need to wait a while, my new grandson is only 8 weeks old!
By the way, by tea time today the gearbox and propshaft are in!!
Fettling was required on the HardySpicer yoke as a very small amount of grinding
Needed to allow the Nyloc nuts to bolt up, plus
The clutch pedal cotter pin hole needed reaming slightly as the
New cotter was reluctant to go through.
At this stage of the build everything seems to need
“Fitting” I now know why the best engineers to ask were fitters,
when I worked at Barr&Stroud’s periscope factory!
I think I’ll try and fit the brake light switch while
the floors are still up.
I’ve been putting off installing the engine but it looks like it will
go in next week, but still lots to do before starting it up.
Bill G
