  • 1 Vote(s) - 3 Average
Sump plate
#21
Details of pickup pipe adapter 10mm 90degree pipe fitting, pump base plate collar dia reduced to fit pipe fitting you may have to shorten the fitting as semi deep
     sumps are not all the same depth so check sump clearance before silver soldering in place.
Terry, that looks neat, but I thought oil was like air, is doesn't like right angle bends?
Can I see a plate under the oil pump,is that blocking the pressure relief hole so that you can use an external adjustable valve?
