(11-05-2024, 10:09 AM)Howard Wright Wrote: Hi Jim and Ruaridh
Hmm, I’ve tested all the coils I have (six) and all are around 1.1 to 1.4 Ohms across the +/- terminals. Most are purchased in the last few years or new! All seem to work well with points and one with the Doctor Distributor electronic ignition. Is a 12volt coil the answer? If so what do I need to do to fit it or does it just replace the six volt?
Just fit a 12v coil with more than 2.4 ohms, nothing else needed. 1.1 and 1.4 ohms will eat the trigger units quickly.
Rupert, happy to chew the fat over your problem, if you want to call...
(11-05-2024, 12:17 PM)Ruairidh Dunford Wrote: (11-05-2024, 10:09 AM)Howard Wright Wrote: Hi Jim and Ruaridh
Hi Ruaridh
Thanks two 12 volt coils on order.
11-05-2024, 04:44 PM
(This post was last modified: 11-05-2024, 04:44 PM by RupertW.)
Thanks Ruairidh, I may well be picking your brains soon!
Meanwhile I did have a successful run to the shops:
(11-05-2024, 01:33 PM)Howard Wright Wrote: (11-05-2024, 12:17 PM)Ruairidh Dunford Wrote: (11-05-2024, 10:09 AM)Howard Wright Wrote: Hi Jim and Ruaridh
Hi Ruaridh
You still need to check they have more that 2.4 ohms, my experience is that they do...
(11-05-2024, 04:44 PM)RupertW Wrote: Thanks Ruairidh, I may well be picking your brains soon!
Hooray!
(11-05-2024, 07:20 PM)Ruairidh Dunford Wrote: (11-05-2024, 01:33 PM)Howard Wright Wrote: (11-05-2024, 12:17 PM)Ruairidh Dunford Wrote: (11-05-2024, 10:09 AM)Howard Wright Wrote: Hi Jim and Ruaridh
Hi Ruaridh
You still need to check they have more that 2.4 ohms, my experience is that they do... Three Ohm is specified.
