Stuart, yes it was one of those. They were quite effective if all you wanted was a full throttle device. The other problem was they wouldn’t tick over and tended to catch fire. All good fun.
Not a wal Philips fuel injector a fire waiting to happen!!!
Today’s exercise , electronic ignition on the AD tourer
There was recently a poll on another classic car forum I post to, this was regarding the reliability or otherwise of electronic ignition packs.
I was staggered when it was determined (by about 3 to 1) that those who used electronic ignition packs were FAR more likely to have issues & when they did these issues were far more debilitating than changing a set of points or a condenser.
If you are worried about reliability, make sure you use good quality spare parts, service your car regularly & keep a spare set of points, a rotor arm & a condenser in your tool kit.
Couldn’t agree more, as with my Ape tourer
For an extra £39 you can buy the workings as a back up. Anybody taken this step?
I can remember my dad soldering the contacts from modern cars ( 1970,s ) onto the Seven points as the only stuff around then was if you were lucky enough to find an ancient garage with stock out the back.
I have been hoarding original points and condensers ever since so I will keep mine original its good enough for 6000 RPM
We went into one such garage to be told they had just recently chucked all the old stock down the local mineshaft.
We are Lucky to have these modern problems to discus.
Use a magneto and you don't even need a battery........
But a spare magneto may be handy.
C
