Besides possibly not aligning jets properly as I understood things form discussion's I had with the former owner of this engine the failure was as attributed to a mason bee building a nest in the oil line, Alistair failed to discover this blockage until after the problems had occurred. He may not have built the remote oil feed to the best design also restricting volume of flow to the big ends, I was too busy to rebuild the engine for him at the time he was asking so did not get the chance to examine it.
Car type: 1937 Austin 7 Special under construction
14-04-2022, 05:44 AM
(This post was last modified: 14-04-2022, 05:48 AM by Humps.)
No, but have yet to get the crank out of the case. Marcus did make one observation that the oil hole in the
journal is blocked, and I always assumed this was white metal as a result of running the bearing, but a quick test with a Stanley knife proved that the blocking material is much harder than white metal?r
Thanks Ian, that certainly answers one question.
Keith
You will probably find that steel from the crank has also embedded into the fill material in the oil hole.
I see that quite a lot when a bronze bearing/steel shaft is run too hot. The bronze is wiped into the oil grooves, but particles and layers of steel do get embedded in it also. Also steel gets embedded in the bearing surface itself.
Once again, I really appreciate all the advice that has been posted and it forms a good basis for inspection and remedial work when I get the crankshaft out.
Unfortunately I got distracted when trying to separate the block from the crankcase.
I thought that they would simply separate, assuming a gasket had been used, but in fact a silicone sealant had been used and no gasket.
Once I had driven in a SS spatula and destroyed the oil-tightness I was committed to the separation which is still proving very stubborn. I am also aware of the fragility of the alloy crankcase.
I have discovered that mineral turps breaks down the sealant, but this does not necessarily penetrate between the two surfaces.
I'll win in the end, it's just a matter of patience and continuing to work at it.
Keith
You have a lot to learn about the idiosyncrasies of successful A7 engine building Keith, not using gasket in joints like the Block Crankcase being just one. Forget the old paper gaskets they will leak, two schools of thought exist, 1; glue the block down with a reliable sealant, there are several people here people who have their favourites, personally I was a Loctite fan. 2; the next school of thought, one which I am now a convert is to use a gasket made from silicon baking sheet, the 7 Workshop and VAR club spares sell them ready cut. I have used them on a number of engines now with no issues thus far, there are a number of others who report to have had the same positive results.
It is questionable whehter oil drops arriving outside of the drilling are driven in by the impact or flung off by cenrtrifugal force. On my standard car I deepened troughs on the inner side
Car type: 1932 RN saloon
I have done 3 engines with doubled up jets. It's a simple mod compared to all the complications of pressure feed and unless you are building an out and out racer it seems worthwhile. Best to align jets with the Forrest "oil in boots" method.
I have now separated the block from the crankcase and this enables one to see the action of the jets.
Using a hypodermic syringe I can squirt fluid through the jets and see where it lands on the crankshaft.
It is immediately apparent that the jets do squirt onto the crankshaft, but in each case they miss the troughs. As suggested by one poster, it would appear wise to widen the troughs?
All other oil passages flow freely including those to the remote oil filter and from there back to the crankcase.
I did find evidence of a Mason Bee nest under one of the valves, so this does give credence to Ian's though about a Mason Bee somehow blocking an oil jet or crankshaft?
The Number 2 big end shows signs of just beginning to break down with the crankshaft lightly scored at one side.
