Ruby steering arm
#21
I have seen belt and braces folded metal overlay arms at the front. With the large nut, would appear scope on the later rear arm.
(10-11-2021, 07:31 PM)Graham Barker Wrote: Does the arm come away from the shaft easily ? Not much space to work in.
It's on a taper and it's up tight. There are shoulders for a puller but no, it doesn't come off easily from memory.
Oh delight !  Here's hoping that the in situ crack test doesn't show anything.
Graham
