3 bearing engine - steel crankcase
#21
and.... Did Military Sevens have Austin 7 style stamped numbering? Presumably there are practical issues about stamping these in the same way as aluminium?
Sand cast too. how very interesting
hi. think it is prototype  or test type engine.if so i want it to be saved.and not chopped about to fit reliant  bits i have in stock ?
How much does it weigh??
i can just pick it up.maybe 3/4 of a full normal engine
My father had one for a while. Complete with block, nosepiece, etc. I remember it was heavier than a Ford E93A block.
(27-01-2021, 03:50 PM)Rogerfrench Wrote: My father had one for a while. Complete with block, nosepiece, etc. I remember it was heavier than a Ford E93A block.
But think how stiff you could make the front of the chassis.
However the extra cornering performance would probably be outweighed by the weight!
c
hi. did your dad know what it was out of ?
hi . roger .could this be your dads engine ?
Perhaps we can see a new thread on here. Instead of All alloy cup we could have All Iron engine
