  • 1 Vote(s) - 5 Average
Front çrank bearing lip replacement
#21
As promised, this picture shows the front end. As can be seen the 6mm x 60mm countersunk set screws pass right through the front end of the crankcase and pick up the original front end retaining plate. Two 6mm locknuts will be fitted to each set screw when the crank is assembled. These nut will not interfere with anything. So you can see, a lot stronger job
