Yes R I agree, although some logic may dictate that the closed end should be at the front those I have see appear to be designed to fit the opposite way round. To be fair if the bonnet is bolted down as intended there is little risk of it taking flight.
I'm pretty sure everyone I've encountered has had the closed end at the rear; as Ruairidh points out, the drillings for the horn mounting usually dictate which way round it goes. With the open end at the front it simplifies removal of the bonnet.
Dave - I see your fuel pipe coil is in the vertical, but tell us more about what you have done to your carburettor. Oil breather and filter on the air intake and have you added a choke butterfly ?
Car type: 1932 RN saloon
Thank you for the photos including the ones on your website Duncan. Lovely!
How thick do you wrap Exhaust bandage ?
I've just remove bandaging from the tail of an exhaust system right up to and including the manifold. I was appalled at the corrosion underneath. Hate the stuff.
