18-01-2019, 12:50 PM
(This post was last modified: 18-01-2019, 12:50 PM by Biddlecombe.)
The Austin Seven Companion when dealing with leak of grease onto linings, states that ".....and the use of the wrong type of grease in the hubs.
I have got Comma GR 2500G Multi Purpose Lithium Grease and Comma CV500G Constant Velocity Lithy-Moly Grease are either of these OK for the hubs or should one or other be avoided at all costs or should I be purchasing a different grease please?
18-01-2019, 01:29 PM
(This post was last modified: 18-01-2019, 01:30 PM by Steve Jones.)
All you need is a good general purpose grease. I've used the first one you mention but at the moment, I think I'm on a Millers version. It all depends what they've got when I buy it. The biggest reason that hub grease on Sevens gets onto brake linings is over greasing the hubs. The original handbooks said that this should be done at regular intervals but all that does is fill the hub with grease to the point that, when full, the grease finds its way past the hub seals/gaskets and onto the linings. Grease the wheel bearings when fitting them, put a small amount in the hub outer, fit the hub and forget about it. It's the way the hub bearings are lubricated on your modern and how often do you re-grease those?
I use a sealed bearing. No need to lubricate and also help seal against stray back axle oil.
OK. So I have the spring pin out, 6 bolts removed from banjo end and all clear with the nearside axle housing hanging. BUT I can't seem to shift it, when I read the books it looks as if I might have to remove the whole axle just to put a new seal in???
I have tried gentle tapping at the brake end. Do I have to remove complete axle or a bit heavier tapping. HELP!!
I've just read back through this thread and whilst I can see lots about replacing the hub seals, I can't find any reference to you replacing the diff inner seals. However, from the above, assume you are doing that also. It is possible, just, to remove the banjo half with the axle in situ with a bit of jiggling but it's far easier to remove the full axle. In any case, you'll need to do that if you're changing the seal on the other side as well. The reason it won't move any further than you've got it so far is that the diff bearing is a light press fit into the axle half and has to be released. Doing that as you've got things risks bending half shafts, damaging the differential housing etc. etc. Much better and easier in the long run to remove the axle.
