02-07-2018, 09:26 AM
Thank you Ruairidh, sounds good to me. And yes, equal levers for sure.
Adapting a rear axle for Girling brakes
02-07-2018, 10:13 AM
(05-06-2018, 11:59 AM)Charles P Wrote:(05-06-2018, 10:57 AM)austin Wrote: Braced front axle on our Ulster: I observed this on Bob Booth's personal chummy and if it was anybody else I would not mention it. To prevent front axle twist under hard braking he ran a small cable back to the radius rod as in Austin's pictures. Bob found a higher attachment point for the cable at the front axle, giving a leverage advantage. Where you ask, well this is where it gets imaginative. The blanking plug on top of the stub axle was removed and a grease nipple inserted direct into the threaded king pin. A swaged loop at the forward end of the bracing cable was dropped over this grease nipple and presto! This was not his racing car. cheers Russell |
