My name is Ruairidh and I too used to be a Morris Dancer.
Go on, it wasn’t the dancing it was the beer that went with it.
02-05-2018, 07:03 AM
(This post was last modified: 02-05-2018, 07:09 AM by Bob Culver.)
Basis for a caption competition.
“That is the 15th pot. Someone have a look at the tail pipe.”
“I reckon it has used a pint per 10 mph achieved”
Perhaps an anti corrosive additive is being used and it is the first any have seen.
“Where exactly did you get this amber fluid from?”
Some cars warrant supervision. I have heard of garage attendants pouring water down the carb intakes of Javelins.
As for the headlamps, from a delve, Cd for a hemisphere is .42 and 1.17, latter surprising same as a flat plate
The shoes here were commonly called sandshoes. Thr plus fours discourage the gearlever or handbrake going up trouser leg.
If so probably supercharged,2% oil in the fuel plus extra supplied by the valve attached via the throttle links.
