27-02-2019, 10:16 PM
After many hours of measuring and making about 30 armoured cables, soldering the end
fittings , and heat shrinking the ends to stop the alloy windings unwinding,
I finally get to fit them and their junction boxes into
the engine compartment.
The pair of 6 way Lucas junction boxes on the inside of the flitch plates
provide power to the dipping headlamps, sidelamps and front flashers,
Plus earth wires as I’m using 6v LED’s all round
When fully wired up I’ll test each circuit out before dropping
The engine and gearbox in. Next nice job is to fit most of the instruments.
There’s a multi core umbilical from the metal bulkhead back to the dash control panel, plus another umbilical( trailer cable) back to the rear lamp clusters.
Any suggestions for getting speedometers overhauled?
Bill G
Bill G
