13-12-2024, 03:51 PM
There appears to be a little oil on the Bendix; this was mentioned earlier in the thread. The other possibility is that your flywheel teeth may be badly worn for which the best cure is a new ring. Fitting this may be a specialist job if you do not have suitable facilities yourself.
