The standard front brake system does not bear too much scrutiny when the wheels are on full lock. I believe Sir Herbert Austin took the view that no sensible driver would apply the front brakes on full lock!
I found that fitting strong return springs to the front brake levers stopped the brakes binding on full lock.
Hi Gordon
May I ask if your desire to modify the brakes comes from experience of driving the car with the original set up?
If so, then by all means apply the changes you are suggesting.
If not, I suggest you drive the car, asses and then make changes that you feel are needed.
For a road car IMHO the uncoupled Austin system is very adequate with one proviso, change the shoes and drums to 11/4”. Adjusting the rear brake cables to get both rear wheels braking evenly is not that difficult.
For a competition car then changes may be well worth it.
I have seen an Austin 7 with a full pulley replacing the original curved track rocker at the centre, and I suspect that this may offer a marginal improvement. As for the ball ends of the levers not being on the king pin axes I think that if the cable can move fairly freely the tendency to tighten on one side will be offset by loosening of the other side, hopefully giving a similar pull on both sides.
I would very much agree that uncoupled brakes are perfectly satisfactory. However, the front brakes can bind when on full lock. This is most evident when the stops have been ground off to improve the turning circle if the car is much used for trialling or autotesting. Bowdenex brakes are helpful for such activities.
I have various old hydraulic brake backplates if you're interested in a hydraulic setup including unmodified 7" Morris Minor ones and a jig to set them up for welding (if you have time to modify them), a set already modified, you might possibly even persuade me to part with a full kit taken from a running vehicle that I was saving for a stalled project.
Thanks for all the helpful replies.
Malcolm, totally agree with the principle of not braking heavily with the wheels on full lock! Your advice of fitting stronger return springs on the front levers sounds excellent. Not certain I understand the mechanics of why this works - I had assumed that the out of line ball was producing the mechanical force so I can only assume that the stronger spring ensures the compensator does its job.
Howard, desire comes from driving experience. I hadn't thought of upping to 1 1/4" drums and shoes. I wonder whether changing the pivot geometry of the non cam end of the shoes to provide self-centering of the shoes would be an advantage.
Nick, thanks for your kind offer but as already said I am going to stick to uncoupled brakes so won't be going down the hydraulic route.
The binding on full lock can be reduced by stopping and applying the handbrake briefly. This causes the front cable to readjust itself.
There is always some slack in the front brake cable caused by the springiness of the cable where it goes around the compensating quadrant under the front cross-member. If you try to remove the slack in the cable by adjusting it at the operating end, the brakes will most certainly bind when the wheels are on full lock. The strong return springs effectively take out the slack from the cable by tackling the problem from the brake cam levers rather than the normal adjustment. Hope that makes sense!
I think there is always a certain amount of play in the brake cams and levers and the return springs counteract this play. The return springs need to be strong enough to take out the visible slack in the brake cable. They also make the brakes firmer to operate which makes them feel more effective.
Malcolm, thanks for that explanation - makes sense to me.
