Balancing rear brakes on uncoupled cars
Big Grin
And I thought the semi Girling compensating linkages on the brake cross shaft was over complicated Confused ...............!
Bob
It is - the very-late rod rear brake set-up is much simpler.
Simplest way to find out which brake is really working and which not? Invest in a laser temperature gun to aim at each drum after a run. About £15 on Amazon.
