Austin 7 Clutch
Yes, exactly that. There is a large coil spring on the release bearing which will push it back off the levers. While you're at it put a few drops of oil down the lubricating tube to feed the release bearing.
On depressing the clutch pedal the large bearing should move forward and contact the three release levers on the clutch housing - this is what you'll be moving:
[Image: OIP.p57NK3lcbgcS0wrJNuPhtwAAAA?pid=ImgDe...&h=177&c=7]
If you move the bearing forwards and re-adjust the pedal clamp there should be enough residual free play in the mechanism to ensure that the bearing isn't rotating constantly in contact with the clutch levers. If it is you can just back it off a bit.
Good morning where is the oil hole on the clutch shaft I have to go to my friend with the AUSTIN 7 this week to help set the clutch pedal Len
There is no lubrication to the clutch shaft, however there is an oil tube on the top of the release bearing carrier, accessible through the hole in the bell housing. Just a few drops is all that's needed.
Thanks
