06-03-2018, 11:37 PM
early speedo drive system
09-03-2018, 12:43 PM
thanks David I have only just seen your reply I was to stupid to realise there was a page two in the replies,can you let me know what you want for the bracket .I have sent you a private email but am unsure if the system always works best regards Rob.
09-03-2018, 10:05 PM
(This post was last modified: 09-03-2018, 10:23 PM by Tony Press.)
(09-03-2018, 12:43 PM)robert regan Wrote: thanks David I have only just seen your reply I was to stupid to realise there was a page two in the replies,can you let me know what you want for the bracket .I have sent you a private email but am unsure if the system always works best regards Rob. Robert - if you used the Forum email see the post at the top- "6-03-2018, 01:10 AM Thank you for raising this, the email system does seem to have an issue, Though I have tested PM's which do seem to work. Looking into it it seems to be a problem that requires access to the the server to test and or repair. I will PM management, but for the moment I'll re-title and sticky this thread, with the recommendation to use PM's till a solution can be found. Sorry for any inconvenience." Tony.
10-03-2018, 09:47 PM
(09-03-2018, 12:43 PM)robert regan Wrote: thanks David I have only just seen your reply I was to stupid to realise there was a page two in the replies,can you let me know what you want for the bracket .I have sent you a private email but am unsure if the system always works best regards Rob. Hi, Please e-mail me: david@a7c.co.uk
04-04-2018, 07:13 PM
my thanks to "Austin in the shed" David made me the complete early speedometer drive for my top hat the quality is second to none, thanks again David best regards Rob.
