Fuel reserve tap accessory
That's reet clever! Fuel flows in from A via B in the 'on' position. As air enters from the vent pipe at B, it prevents  a syphon forming. Whe the fuel level in the tank reaches the same level as B it acts like a baffle and stops the flow. The reserve setting directs flow straight from A to C, allowing the tank to empty.
Hi Nick
Thanks, I’d got most of the way there but your explanation is very concise.
And I'd be brave enough to guess that the internal passages look something like this... at least without one to look at, I can't see how else the geometry makes sense.
Try a tee port cock
