Steering column advance / throttle tubes
(02-03-2018, 12:13 PM)ollyS Wrote:
(01-03-2018, 01:52 PM)tube sizes Wrote: further to first post and other replies here are few pictures and details
the outer original tube with car and has thrust bush on end Part BM136 has OD of .561 and ID of .360
The first rotationg tube brass and part bm130 has OD .497 and id.401 ---- this is problem as will not fit into above part.
the final inner brass tube ( which fits above) Part bm129 has od .375 and id.320
Olly
Something amiss with those dimensions ?
Tony.
Olly
Tony.
I think the clue is in the brass tubes. Were the originals not steel?
Olly
Tony.
Yes but the static tube is quoted as 'Part BM136 has OD of .561 and ID of .360' - not much larger than the bore of the inner tube size shown.
I spent many a long hour with emery tape to get a replacement static steel tube to fit nicely inside the steering column tube on the Sports Car  Big Grin
Cheers, Tony.
Any idea's
Olly
If any of my parts don't fit, it would be really helpful if I was told about it direct instead of happening to come across it on the forum! Then I might be able to do something about it. I usually supply all the three tubes together, which do all fit together nicely. This is the first hint that I've had that there might be a problem with them. I think the 9/16" outer tube I am getting is thinner than the original, and the 1/2" tube is thicker. I will see if I can get some tubes which are more like the original ones.
David
Any idea's
Olly
David
David,
I hasten to add my static tube was a local Australian supply, not from you.
Tony.
Any idea's
Olly
David
Firstly may I say apologies for any upset I have caused.i have only ever had excellent advise, help and parts from David and I hope this has not been taken the wrong way.
When I tried to fit the tubes I was confused and thought it an interesting deviation from the norm. I was thinking and still am that it is an anomaly with my set up - I was hoping it may be a bush or something that had been added.
I am not about today but will call you (David).
Apologise again
Olly
(03-03-2018, 07:47 AM)ollyS Wrote: Firstly may I say apologies for any upset I have caused. I have only ever had excellent advise, help and parts from David and I hope this has not been taken the wrong way.
Apologise again
Olly
No upset caused, so no apologies needed! Just a minor whinge on my part. And of course, today I completely forgot to check my new tubes against the set of original ones - bother. Tomorrow I should be mostly away working on the RP again, but I will try to get round to looking at them.
David
Having got tube red hot / bored end to 12.4mm and smack with ‘intent’ there is a witness of old inner tube (solder appears to have run down between tubes) I have finally admitted defeat. I think a trip to see David for an outer tube is called for !!
Will add pictures shortly
(04-03-2018, 09:33 AM)ollyS Wrote: Having got tube red hot / bored end to 12.4mm and smack with ‘intent’ there is a witness of old inner tube (solder appears to have run down between tubes) I have finally admitted defeat. I think a trip to see David for an outer tube is called for !!
 Your original comment- " the outer original tube with car and has thrust bush on end Part BM136 has OD of .561 and ID of .360" should have been a clue to this !
Cheers, Tony.
