09-06-2023, 01:55 PM
(08-06-2023, 11:34 AM)Ncoates Wrote: Charles,
I shimmed out using some circa 16-14 swg ali sheet. I think if it was just binding that would be sufficient.. I've decided to bite the bullet and take the engine and box out to investigate it further. At least I can see what's going on on the bench, rather than grovelling under the scuttle!
Nick
Please report back.
I've had a similar problem when using a machined down a 4 speed flywheel with a 3 speed clutch cover. The flywheels have more differences than just where the teeth are!
Charles
