I'd like to know more about the oiler idea.
I have never managed to get grease to flow through my semi girling stub axles, it prefers to escape from around the upper blanking caps despite these being tack welded in place by Vince Leek when he refurbished them. Goodness knows how much pressure is being applied from the lever type grease gun. Even warming the grease and the stub axle doesn't seem to help. Maybe the clearance between pin and bush is just too small ?
On advice from my father back in the 1960s I have always used SAE140 back-axle oil - I retain the standard grease nipples and have a dedicated grease gun filled with oil.
I have a semi-girling front axle on the RP and when greasing, the nearside reataining cap has a habit of being pushed off by the pressure of the grease gun. I get the Melm'Sahib to wedge a tyre lever between the plug and the adjuster moulding while I give it the beans with the grease gun. Works every time. Strangely the offside one never budges.
A bit off topic, sorry! But almost relevant
I have a Rover 12 tourer that is fitted with a Luvax-Bijur total loss automatic lubrication system and no grease nipples The theory is that the manifold applies a vacuum to the "system" which then pushes SAE 90 round about 23 lubrication points, No vulgar pulling on a lever or pushing a pedal (like on more ordinary vehicles like Bentleys!) Rovers do it automatically when the car decides it needs it!
Where does this have relevance to Sevens I hear you cry?
There is a blanking plug immediately after the reservoir and into this it is possible to screw a "suitable nipple" (unspecified in the manual. Using this it is possible (apparently) to pressurise the system in order to check if oil is reaching the relevant moving parts...that other oils cannot reach...
1. What sort of nipple should I use? A straight on would be ergonomically easiest! A brake bleed nipple fits the hole, but would not, I imagine, be any good to apply pressure to check the system!
2. I don't have a pressurised oil (as opposed to grease) gun....What is suitable? A Wanner perhaps? They were always good on grease and I recall they were ok with oil ..I had one in the 60's for my mini...both long gone!
I can add that there are a number of puddles on the garage floor, which tells me the system is working, but NOT whether it is getting to all the places where it is really needed (like king pins!)
Helpful advice will be appreciated
David
David,
The Tecalemit system is similar to the Luvax-Bijur one on your Rover 12. The system is served by the vacuum in the inlet manifold and activated by a button on the dashboard. A shot once a week is recommended. As on yours, no grease nipples.
Further investigation suggests the oil could well be SAE 140, already in the reservoir.
Interestingly I contacted Tecalemit advising of their '20's system on the car, thinking they might be interested and asking what oil they would recommend. One first count they showed no interest and on the second, recommended hydraulic oil! So much for their technical expertise.
I use a Wanner to fill the rear axle on my Brooklands...the access hole being obscured by the body work / floor pan.
Car type: 1934 RP Saloon
Chain saw oil is very good for kingpins as its sticky and doesn't run away. Available from Machine Mart and other suppliers online. Used it on steering trunnions when I had a Lotus Elan.
It is possible to alter the girling stub axles to accept screw in brass plugs instead of the core plug type caps.I think I used M20x1.5 and grind a tiny bit off the length of the kingpins and then they can't pop out when greasing.
