Hi
+1 from me.
Make sure you seal the helicoil in with Loctite as well as the sump bolt. A few of the stud holes are not blind and oil finds its way down the threads.
My advice is if you have the engine out and working on the sump is if the first couple of threads are pulled,or the bolt is a bit loose in the thread when checking is just fit a thread insert. It's much easier than trying to do it in situ.
The worst situation is when someone has previously tried to drill out a broken bolt and the hole has run and or been bodged.
I use large quantities of stepped studs and helicoils, every year.
Both work equally well, if fitted correctly, in my experience.
My experience of helicoils for the sump is you need to use a Helicoil plug tap to stop the inserts being threaded into a tapered thread as left by the normal taper tap. This is due to the holes in the crankcase being quite shallow.
A plug tap or bottom tap can be made by getting another tapered Helicoil tap and shortening it without overheating it.
I am sure others have views on this.
You can use an m8 plug tap.
Ah, youth and enthusiasm, I’d have gone home.
I have decided to go along the route of oversized bolts as there are only two threads too repair and I intend to do the job with the engine in the car. I will be using a silicone gasket. As to youthful enthusiasm that’s how the threads were stripped in the first place. My son is to strong for a light job.
John Mason.
