Thank you - I'm pleased as punch with it - I had that saying about most fuel problems being electrical ringing in my ears all day yesterday and today LOL.
I'm still going to fit a new diaphram to the fuel pump and give the carb (yet another) clean.
Joe, Have you thought of the old saying “If everything is ok then leave it alone”. Or “If it ain’t broke then don’t mend it.” I refer to of course to your comment on the fact it is pulling like a tractor. I would however do something about that stripped thread.
John Mason
With a repaired dizzy and all the other bits I had a fantastic day out with three of us in the car yesterday. She's revving well, picks up perfectly and pulls really well. Thanks all for the help!
In that case I would stick with the proper Lucas distributor. As you have found out, you can at least repair/overhaul them, unlike a Chinese electronic gizmo.
Hi Joe
I tried an electronic base plate mod (from accuspark I think?) in a DK4A. I didn’t get on with it, probably because I am more used to a manual advance and retard. As Malcolm has mentioned points can be repaired / replaced easily and cheaply. Also I don’t think most electrickery includes advance and retard so you are still relying on the old bob weights (often a source of trouble on older distributors).
All the parts you require the refurbish an auto advance distributor were available quite recently. I couple of years ago dismantled a Chinese or perhaps Indian copy and found that it was so well made they had even replicated 90 years of wear into the design! The advantage of electronic is that you don't suffer the point float/timing scatter that you do in a worn out unit, hence the cheap knock offs appear a good idea by apparently improving running in the short term. The problem is they are not all that reliable on a noisy 6V electrical system and cant be fixed as easily when they break down. I also did tests against a properly refurbished original DK4A and found absolutely no measurable performance advantage.
I had my own distributor over hauled shortly after I had my car in 2018. Since then, the ignition system has been completely reliable. Although I check the points gap every 2500 miles, I have not yet had to reset them in a total of 15K miles covered. And, as Ian points out (sorry for the unintentional pun) you can fix any problems easily - on the side of the road if needs be.
I find the electronic units on my own cars to be super and reliable. Most failures I have encountered are because of faulty wiring, causing a spark, or using coils that have less that 2.4 ohms of protection - both of which will fry the units quickly.
I always carry a conventional spare with me, in case of breakdown, but then I always did before using electronic ones.
