13-02-2018, 10:09 AM
There are 2 variants. One has the coil of wire and a 3.5 volt bulb. The other has no wire coil and a six volt bulb.
It is easy to convert the 3.5 volt to six either by replacing the wire with a resistor as Dave suggests or removing the wire and fitting a 6 volt bulb.
