Axle oiling
(25-06-2022, 06:54 PM)Dave Mann Wrote: There used to be a time when the oil was supplied in plastic bottles which had a 4" long tube in the cap for filling axles, I have one and stuff the tube in the hole and squeeze simples.
Ditto — this works well but Jack up the rear cross member as this drops the axle into an ideal position for access.
This is available in the Antipodes.
I went for this on Amazon. It worked very well. Jacked up the car on the cross member as Reckless recommended.
