02-06-2022, 10:43 AM
(This post was last modified: 03-06-2022, 12:02 PM by Tony Griffiths.)
The instructions claim a 10-metre - and this does check out. Tried with the engine running in the garage - and they d0work. Knowing the vagaries of the A7 ignition system that appears to vary with temperature, humidity, cloud cover and what one consumed for lunch - an open-road test will follow - which was successful. The only fault I can find is that the controller has a weak sound and rather dim light. Could it be linked by Bluetooth to a raster-blaster?
02-06-2022, 11:45 AM
(This post was last modified: 02-06-2022, 11:49 AM by John Mason.)
I have a Ruby and like others not wanting to drill holes in the body or wings. My answer was to attach the indicators on brackets to the rear of the bumper using the outer bumper bolts. Fronts being above and rears below the bumper. This puts the indicators nearer the corners of the vehicle than it does with number plate mounted.
John Mason.
I wonder, Mike if your ignition system was fitted with suppressors it might help?
I think it's the screening of the steel body, the fronts are working fine, but not the rears.
I've just done an extended test, with Anne following to check, and on mine the left rear is reluctant. The others all work and so, as a temporary job is will have to do. I like the cunning mount you cooked up!
