No 2 looks like a device to turn a tap on and off...I have a long thin version to open & close stop cocks.
This next should be in pedants corner..... No 3 the plug holder (?) has been fitted since the late 50's...it appears to be held on by blind (pop type) rivets....not in general DIY use until then!
Is No2 for fitting over the brake pedal butterfly nut on cars that don't have a hole in the floor?
For decades I have carried one plug in family cars and thought that a bit pessimistic. About 1960 on a 60 mile trip a plug failed in the RP. I carried on with it removed until a garage 40 miles later. The owner was so taken by nostalgia that he went to great trouble to find a correct used one amongst his odds and ends. I think a plug would be less at risk under the seat than in that gadget.
Someone was pretty desperate to get that flywheel nut off!
A desperate attempt to "add lightness"?
I suspect the drilling on that nut at 8 o'clock probably didn't do the crank thread much good.
