Scraping White Metal
Hi Steve, yes indeed DO… she’s been off the road too long now so want her together!! Steve C did my last lot if white metal on the special so yes he is good! Any ideas when the engine work was done?
Think I’m also going to change the chassis extensions as those fitted are rather thin and the rear needs support… no one likes a saggy rear with cracks around the openings ?‍♂️
Be interesting to test the old crank to see if it defies statistics. The butchery can be countered but the damage from the very  common welding/brazing etc cannot.
