Car type: Austin 7 boat tail tourer 1931
I think I'll start with a round hole to get the through bolt out. If that works OK I'll probably try and lift the body a little to get the U Bolts out, but they don't look too bad so if they have to stay in place it shouldn't be an issue. I'll try and take a few photos as I do it which may help others in future,
Thanks
Steve.
Hi Steve
It may be worth looking at the body mounting points on the chassis. Although on my RK the spring bolt holes were close to the stiffening rib they weren’t that close. I doubt the boat tail floor pan rib would have originally covered the bolt hole. So it may be that the body is not correctly positioned on the chassis. I don’t know the floor pan mounting points on the boat tail, perhaps others could advise?
I am sorry Steve I know this may sound harsh, but under the circumstances I feel your approach was ill advised and you would have been better off lifting the body, which is not actually that difficult. The car has survived unscathed 90 years and damage you have inflicted will now be very hard to repair properly will always be there. This should be a lesson to all that cutting corners is not always a sensible approach, far better to slow down and consider the options and outcomes.
Howard, You may be right, however I suspect in fact the floor may not be original and the rib may have been replaced slightly further forward than originally.
Ian, I don't disagree in principle but I doubt the current floors were there 90 years ago. I suspect they were replaced some time ago and the strengthening rib was replaced in a slightly wrong position.
I'm pretty good with a MIG, so I'm confident I could put it back to look exactly as it was before I cut it, however I think I'll make a box up to fit around the bolt hole so that it could be removed again if needed.
Cheers,
I have never dismantled a rear spring. A colleague recently mentioned that there is some complexity with the rivet and not straightforward. Can anyone elaborate please?
(I suppose usual precautions about the spring exploding needs be observed. A neighbour knocked himself unconscious with a spring)
I have heard oldies recount how springs were restored simply by hammering cold on a semi hard surface.....
