04-08-2021, 10:20 PM
R4 is 1.5" crank, no?
Reliant Regal Pistons?
06-08-2021, 02:07 PM
(04-08-2021, 09:43 AM)Chris KC Wrote: My set had an oil control ring missing, I replaced it with one of Jamie's - as far as I can tell they are identical. Austin 7 ring = 5/32", Hepolite 17229 ring = 1/8". QED?
Parazine - I don't have the parts to hand and may have confused myself.
Either way, if you have a piston with rings this would not be a barrier to using it. The pin size is not insurmountable, but in the present spares environment it seems not quite justified spending time or money on the job.
08-08-2021, 09:13 PM
I concur. That's why I nicked the compression rings and relegated the 17229 set to the autojumble pile for someone else to use or worry about!
10-08-2021, 10:57 AM
I think I might hold on to mine - could be made to work if the need arose. We are blessed with good supplies of important parts at present but that can change so easily.
