02-01-2018, 03:04 PM
(This post was last modified: 02-01-2018, 03:12 PM by Tony Betts.)
Hi all,
This one wasn't burried, I took it out of the shed about 3 months ago. Well it was easy to reach. And I didn't want to loose it.
[attachment=1783]
[attachment=1784]
[attachment=1785]
For those who haven't noticed yet, it's a 1923 head number 1348. Deep recest plugs.
Yes lovely big hole in the top.
I didn't want to bin it, 1923 heads don't come up very often.
If anyone can repair or get it repaired cheaply, please get in touch.
It will save another early item.
Tony.
I may be mistaken but I would suggest a brazed repair might be less risky than a cast-iron weld? Scrupulously clean at the joins and allowed to cool very slowly to avoid thermal shock and distortion.
You'd need a fair old blow lamp though!
Cast iron can be welded quite easily using stellite rods, but the workpiece needs to be HOT beforehand. I'm sure there is information available on how this can be done. A good professional welder would know how to do a good repair to this head.
I have repaired damage such as this both by brazing and gas welding with cast iron rod. When welding, I heat the piece until it is red hot, the slow cool down by burying in an ash bin full of vermiculite(expanded mica). Now days with cheap computer co trollers, I would build an electric oven to heat and cool the piece being repaired. I have also repaired cracked blocks at the head gasket face by "botton holeing" the cracks and closing the crack with interlocking, shop made, threaded copper rods which were peened to expand them after installing. The plugs were then draw filed flush with the block after peening. I learned this method from a pre WWI era mechanics repair manual.
Today was the first day of the shed built.
No pictures to show you, as no builders turned up.
Typical.
I'm now being told mid morning tomorrow, sounds like that's when the kettle goes on.
Tony.
04-01-2018, 12:37 AM
(This post was last modified: 04-01-2018, 01:15 AM by Bob Culver.)
it is a curious fracture. Is it very deeply rusted or some casting flaw? Would hardly develop enough pressure to fracture. Has it been hit with a pick (mark on right?)
Living in sub tropics frost damage almost unknown!
Tony, couldn't you bundle together parts of a similar age, with a chassis and block, and sell to special builders.
Highly skilled and intelligent chimpanzees like me could give them a new life!
