Dip stick
Nothing, other than the ring part of the stick going right down to the hole.
my ring on my RP stick hits the rim hole first..
ooh er misses
For some unfathomable reason, the dipstick on my RP only measured 3 1/2 pints when the sump was filled up to the 'Full' mark. I therefore filled it to 4 pints and marked the stick where the new level came to. The difference between the two marks is 5/16 in (approx 8 mm) which represents 1/2 pint.
Hope this helps!
