21-12-2020, 05:05 PM
Head removed - wet areas in zylinder 3 & 4
21-12-2020, 08:03 PM
The more oil burned the more rapidly oil blackens. Nevertheless that degree of blackness and tar is more characteristic of pre detergent oils. Are the oil rings totally plugged?
The top land has been rubbing but very common, esp as split skirt pisons soon devlop clearance. Can get a vague idea of taper from change of ring gap; nearer 1/2 then 1/3. When were angle cut rings last marketed?
21-12-2020, 08:36 PM
Hi
That is a seriously dirty engine. When I cleaned the crankcase on the RK I joked that we both had a serious paraffin bath together ![]() Your photos are great. Please keep them coming as you start to rebuild. Cheers Howard |
