RPWindscreen Adjustment.
Is this a RP chrome on brass windscreen or is it the earlier RN steel frame which for some inexplicable reason has found it's way onto an RP saloon?
On my RP, the lower (U shaped curve) section of the windscreen is chrome plated steel. The top rail is brass.
    This is the RN steel windscreen frame section which uses a different seal and closer to the RP.
