Air pressure gauge
Sorry Dave, another red herring
This is on Amazon in US, so has an NPT connector. Face looks reminiscent of the David Harcourt gauge. There is a Kodiac version that looks identical, but presumably has better internals at twice the price.
https://www.amazon.co.uk/dp/B00FBPPY1Y/r...DFb427RV5G
Something like this Dave.
https://www.ebay.co.uk/itm/233575863432
would this one suit you or be modifiable??? https://www.prewarcar.com/311414-flanged...ge-special
Too high a range Michael,10 psi full range would be max.
I bought a low pressure gauge  2",new modern industrial type off Ebay a while ago with the intention to convert but it would be nice to come up with an original gauge similar to the rest I already have if possible.
I used a standard A7 one on an oil drip feed on a 1898 Panhard. The pump came from a paraffin lamp and the rest I made from copper pipe, sheet and brass fittings. The gauge between the air reserve and the oil tank. The first I made with 2 pumps worked but needed more attention. 2 Brighton runs no problems. Pete
I should have said standard oil pressure gauge. Pete
I found a suitable smiths 5 psi oil gauge to convert with a good face. However Greg Clarke has produced an excellent 0-5 reproduction too as would be fitted to Bentleys etc.
    Here's mine Dave.
  Later 0-5 Smiths gauge put into an earlier casing with new face.
Looks very good.How did you do the face,Robert ?
Tony B can supply a face which you can colour to suit your other instruments.
Or you can print your own on coloured paper.
  If anyone knows a good screen printer who would be prepared to make small batches I would be very interested.
