Smashing illustration Tony.
Since we all love a detour - my father worked as a mechanic at Hersham & Walton Motors at the end of the 1950's. Apparently at that time FWD Citroen transmissions were either costly or hard to obtain (I don't remember which). He maintained that whenever the HWM team crossed the channel it would come back with a few Citroen boxes in pieces and loosely described as 'racing spares' to any customs official who happened to look in the back of the truck! Every little helps as they say...
Tony's work is to be applauded and yes, it would be nice to create a collection of these for the Archive. I would rather gather a collection of the magazines themselves, if possible, and have appealed in the past for such things.
Offers of donation, loan or sales are always welcomed. For example, Light Car and Cycle Car, Austin Advocate (and subsequent 'Magazine) plus original 'period' photographs are keenly sought...
Thanks Mike for a very impressive photo.They dont make things like they used to. Very curious as to how. Nor do they wear dirty overalls as they used to. I am also curious how such were ever cleaned!
Ironically the weak point of the Traction Avant was the cw and p!
As far as I know Seven synchro boxes give no serious trouble due failed thrust washers but many others do/did. The pieces going through the gears compound damage.
Hi Mark
A colleague recently spent a lot of time rebuilding engine and gearbox of a very nicely restored L15 correcting wear and many assembly errors. All back together it transpired someone had fitted an early model replacement low ratio cwp so he had to take all the front end to bits again!
Hi Parazine
If you can drive home or it does not deposit bits on the road, trouble is not serious!
Very many cars, possibly led by Ford from early 1930s, had loose thrust washers on the mainshaft. These break and the bits often wreck the rest of the box.
Car type: '27 Chummy, '34 Special, '50 Traction Avant
Yes I think the problem with the traction transaxle only manifests itself with a very worn crownwheel and pinion. The local club produces an internal reinforcing plate that holds the casing together, maybe Cooper bib something similar.
Mark
