No.1 is a greaser, you load it up with grease and turn the cap every now and again to lubricate the body of the distributor.
If you have an auto advance distributor, it doesn't need lubricating, since the body only rotates when you are setting up the timing. So there may be an oiler rather than a greaser. Often missing.
If you have a bit of vertical movement, you should be able to rotate also.
Car type: 1932 RN saloon
Try removing pinch plate bolt and gently prising the pinch plate apart.
Car type: !938 Ruby
20-08-2020, 11:51 AM
(This post was last modified: 20-08-2020, 11:52 AM by Hobbo.)
Hi all, eureka have just got it free, undid the bolt and overnight sprayed with plusgas, it was still very tight but worked back on forth and have now got movement. Looking at the threads on the bolt shown on the picture, it may not have gone fully home in the first place, lesson learned examine everything carefully before undoing. Many thanks for all your valued help, back into the garage to do some timing adjustments. Thanks all Mike p.s. have still got in place little oiler tube
21-08-2020, 08:01 AM
(This post was last modified: 21-08-2020, 08:02 AM by Reckless Rat.)
Tony, err yes. Look at the picture... Bosch 009, manual control ( present but redundant).
