06-08-2020, 09:04 PM
ok, next thing is what manifold have you got - if its not a Ruby one then the angle it sends the downpipe off at could be slightly different?
Ruby, Exhaust Downpipe touching chassis
06-08-2020, 09:17 PM
I had this problem after fitting a non-standard exhaust manifold. I solved it by getting a friend with a milling machine to make me a very slightly wedge shaped steel spacer to fit between the manifold and downpipe flanges. I also needed two flange gaskets and slightly longer bolts.
OK...Looking at Colin's photo, my pipe is not straight like the one in the photo, but kicks out toward the wing slightly.
John, I think you have provided the solution. I will mill a wedge shaped insert between the pipe flange and manifold. Thanks for the info. Ian By the way, how do you post photos? I can't find the instructions.
07-08-2020, 12:50 AM
07-08-2020, 03:39 AM
(06-08-2020, 09:45 PM)Ilmoro Wrote: OK...Looking at Colin's photo, my pipe is not straight like the one in the photo, but kicks out toward the wing slightly. Under 'Important Threads' at the top of the first page see: Posting images on the new forum
27-08-2020, 01:04 PM
![]() ![]() ![]() Ian |
