Hi Squeak
I feel like a priest at Confession. On old Sevens nothing can be assumed! Owning a lathe is a mixed blessing. Everthing is seen as a challenge of ingenuity.
Hi All,
I've used commerically avaialble shimming washers in this application with no ill effects yet. For mind it's a better solution to insert a high tensilte shim and get maximum torque on the nut than to "back off" to the next castellation.
Steve & Tate Davidson
Perpetual Amateur Austineers
With a taper joint backing off to the next castellation will always fail; it is fundamental that the taper be kept as tight as is reasonably possible. You can remove a whisker from the back of the nut with emery paper on a surface plate (or plate glass if you don't have a surface plate), just enough for the nut to line up its next castellation. I see no reason not to use a washer if the nut goes on too far, but care is needed if the taper has been lapped. The pinion on the end of the shaft must not be in contact with the inside of the differential housing. If it is you will find bits of silvery looking metal coming out with the oil next time you drin the axle.
