17-05-2020, 10:28 AM
(This post was last modified: 17-05-2020, 11:49 AM by David Cochrane.)
I used to get my brake linings bonded, but the photos above show why I don't now. The companies fit lining material that is too wide, then grind it away until bits of brake shoe start coming off!
Good quality high-friction linings are available from the Seven Workshop (grey material) and A7 Components (woven material) at a far lower cost. Please support your cherished suppliers!
17-05-2020, 10:39 AM
(This post was last modified: 17-05-2020, 10:41 AM by Nick Turley.)
Saftek is the way to go, no question.
On alloy shoes I have them bonded and riveted, on steel shoes I have the bonded only.
Car type: Seven Special
David, please enlighten us as to the specs of your high friction woven material.
Thanks,
Paul N-M
I have only ever had good results when using A7 components or Seven workshop linings, I have however experienced some terrible bonded linings, incorrect material, bonding breaking and damage to shoes. However that said I have seen some dreadful home fitted riveted shoes as well so I don't think either option is any guarantee of a good job. My advice if you wish to take it is, provided you have the skills fit them yourself, if you don't go to a recommended professional with known experience of our cars.
Car type: Austin 7 2 seat tourer 1935
Many thanks for input. I’ve decided to play safe and have them bonded.
