Hi Colin
You need quite a big lathe to swing the nose cone, the alternative being to use a fly cutter. I had neither a big lathe nor the required fly cutter but fortunately someone before me had attempted a repair and left quite a big hole. Hence the side locating bolts in my fix. However be careful with getting the repair exactly in line with the starter dog and handle hole otherwise the handle sticks in the dog. (don’t ask how I know this).
Car type: Type 65 1934 + RP 1932
Cheers Howard. I have a small Myford, so will have to hold the work in the cross slide and mount the tooling in the chuck. I had considered a fly cutter, or an end mill, or even mounting a boring head in the headstock taper. I will have to buy the milling hold down gear to mount the nosecone, and don't have any tooling other than HSS tool stock I grind myself, so am looking for a steer on the best tool for the job. Concentricity will be an issue, but is achievable. Whilst I'm in there I intend boring and sleeving the front hole on the nosecone to prevent rattle and the ingress of crud, so am considering making up a boring bar to do both jobs by boring between centres. Lots of options. Experienced advice needed!
Car type: 1932 RN saloon
Dave Dye did a great job on my chummy by welding a new shaped boss inside the nose cone.
Thanks all, food for thought, and very helpful photos.
Car type: A7
16-05-2020, 07:41 PM
(This post was last modified: 16-05-2020, 07:42 PM by Douglas Alderson.)
Depending on how worn the inside of the nose cone is e.g. stays in place but drops going over bumpy road. It can be fixed by using a Ruby starting handle spring and then cutting to length slightly longer than the current length as this then applies a bit more pressure.
Car type: 1931 RN, 1933 RP
I feel,the greatest advantage of the handle being reliably parked at the nine o’clock position, whether it was designed to or not, is the handle not hitting a kerb when parking end on. And hence breaking the nose cone.
Roly
1931 RN, 1933 APD
It also obscures the number plate if just hanging down
