28-02-2020, 05:10 PM
Insert Nuts Type D M6 x 20mm 50 Pack (61859)
Product rating 4.7 out of 5 stars (23)
I know it looks like a knock in, but if you are familiar with them, the difference in configuration of the exterior protrusions is easily seen.
This is a "D" nut, other versions are available. Usually under the general heading of "furniture fixings" in most fixings supplier's catalogues.
You can get different lengths, which means you can get a heavy duty fixing - I use a couple on the special to hold the non-removable bonnet sides on to the scuttle hoop.
They haven't moved in 9 years.
They are only made of some zinc derivative, so will self destruct if the hole drilled is too small/timber too hard.
That also means they are easily drilled out if that happens, and you can move up from (say) M6 to M8, and try again.
Not very effective in end grain.
