Crankshaft clearances
(12-02-2020, 01:32 PM)Alan Wrote: There’s a very distinctive tinkling sound as the revs increase when you get it wrong. Don’t ask how I know that.
Also, In case you get it wrong, a very quick oil change with a detailed examination of the contents can be instructive. Steel on aluminium doesn't ring in quite the same way and the residue isn't magnetic.
On a side note I do wonder if Terry has a photo to answer *every* sports Austin query!
C
Hi Folks,
Just another renew of this thread.
I have been installing a Hadley Crank and Rods into a sand cast Nippy Crankcase.
I recently installed the block pistons and rods only to find clearance issues.
I tried fitting the angled rods one way round and they fouled the camshaft so I turned the rods around with the result that the big end bolts fouled the inside of the crankcase.
As it is easier to relieve the crankcase that is what I am currently doing the big end bolts foul the case higher up than the recesses in the Nippy case and only for about 1/4" of crank travel.
I have laid the Crankcase on its side and put a workshop vacuum cleaner hose into the oil filler hole and have been hand scraping away at the wall to get sufficient clearance for the rod bolts.
I was tempted to grind a small amount from the Big End Bolt heads which would have been easy to do on the lathe with its grinder attachment but I decided against doing that as the rotating assembly has all been balanced.
Once I am happy with clearance it will all be vacuumed and wiped out followed by copius flushing with brake cleaner before I close up the bottom end.
I usually solve this problem by machining a bit off the bolts, but if you’ve already had the balancing done I can see your point. If I have 50 thou clearance it seems to be ok.
This engine had clearance problems
Same on this one.
Thanks for all your great pictures and input.
It looks like every case is different !!!
In my case I have not noticed any rod clearance issues where the oil baffles normally live.
I also seem to have sufficient Camshaft clearance.
My camshaft is a one off from Newman using flat button cam followers which allow for a more modern softer profile than the Nippy Cam
I did have to reduce the outer shoulders of the centre bearing to allow the followers to fit which was a simple job on the lathe.
I have a bit more scraping to do for big end bolt clearance. I opted to use a scraper which I made out of a round file as it makes less mess than other faster means.
I will check all the points raised by your pictures before I continue the assembly work.
My current engine has a pressure fed Gordon Allen 1 1/2" Crank and Rods which was assembled about 30 years ago into a standard crankcase I dont remember any problems with rod clearance but that might be due to it being a die cast case which will have thinner walls than the sand cast Nippy / Speedy Case I am using. ( This case might be a factory replacement as it has no engine numbers on it )
Cheers Richard
