19-06-2019, 01:11 AM
Isn't there something about needing negative earth ?
Car charger
19-06-2019, 08:17 AM
Tony
If you use an insulated socket then it doesn't matter as you are just providing a 6v potential difference across the lighter socket. The earth of the socket then simply becomes -6V and in practical terms 0 to the sat nav, and the 'positive earth' of the A7 is providing a potential difference of +6V. That's why you must use an insulated socket so that you don't put 6v positive from the A7 bodywork to the earth of the socket/sat nav. As i noted, some have previously noted an initial voltage surge due to the lack of any voltage regulation which can damage the sat nav, but I have not experienced any problems in 10 years. Andy
19-06-2019, 08:28 AM
I am now out of touch with such matters, but there is a huge amount of radio interfernce under the bonnet of completely unsuppressed cars. Dunno if any spikes find their way thru the bulkhead but a bypass capacito or shielded cable may reduce any spikes.
19-06-2019, 08:57 AM
Just put a capacitor across the terminals, as close as you can get it to the output socket.
This short circuits anything that isn't direct current - so cuts down the interference. If you can use a capacitor that will do in (or just outside) the distributor - very good. A neat way of carrying a spare. I bought an indicator unit from a well known supplier, along with LED festoon bulbs. They are lovely and bright, but wouldn't work properly until I put the capacitor across the unit as recommended in the instructions. Simon
19-06-2019, 04:21 PM
I use one of these from Amazon. It is insulated.
Idealeben Dual Car Cigarette Lighter Socket Splitter 12V 24V Charger Power Adapter £15. Roly
1931 RN, 1933 APD
20-06-2019, 08:47 AM
The socket I have was for use on boats. It's waterproof and has the facility to disengage the charger without removing it from the socket. It also has a cover for when it'd not in use.
20-06-2019, 12:45 PM
My socket is one for a motorcycle which allows you to mount it on a flat surface without cutting out the large whole in the dashboard. It is also waterproof..
John Mason
