14-06-2019, 09:41 AM
end of dynamo. what is missing
14-06-2019, 10:26 AM
For those without lathes much can be done in a drill press. Nuts can be held sationary while a file on a block of wood is pulled under. Then nuts can be finshed by dabbing down onto emery paper etc.
14-06-2019, 10:37 AM
![]() This is actually on the end of a Dynamator but I'm sure it's the same.
14-06-2019, 10:41 AM
(14-06-2019, 09:41 AM)andrew34ruby Wrote:(14-06-2019, 09:21 AM)GK5268 Wrote: If you can't get a correct nut, why don't you just cut this overly deep nut down to size? That way you can fit the blank disc cover without any modification! Then you need to get one! If they are identical to the block core plugs, as suggested earlier, then they are readily available here: https://www.theaustinsevenworkshop.com/p...g-knock-in and other places.
14-06-2019, 10:52 AM
I've certainly found Bob's suggestion is a good way to tidy up recessed tappet screws.
14-06-2019, 02:31 PM
